Why do I want oil going into the intake from the engine?
#41
Exactly. If this was a motor killer, they would devise another method to deal with the little bit of oil that gets mixed in with the gas and burned off. What do other bikes do? After a zillion miles on my $5000 Adventure bike a bore scope easily indicated the part numbers on the pistons. After 4000 miles my new razzle dazzle 121hp 107" Harley motor went south and the new CP pistons looked like this....and yes, when I built the motor I made sure I did what everybody says "you must do" and I routed the breathers so there was a big spot of oil on the ground whenever I stopped. So these pistons from day one had the breathers dumping to the dirt, no oil getting in the chambers...
If "there was a big spot of oil on the ground whenever I stopped" from day one then you had issues from day one...
What went south on your 107??
#42
Even though you vented to ground, there's plenty of oil getting in those chambers,,, looks like a bit too much fuel also...
It was partially my fault as I myself did the cams, heads, bored jugs, (basically all the top end mods), knowing I had a .007 runout on that crank thingie.
I got the entry level port and intake valve size increase by Don Dorfman, when the heads cam back from him they looked like a thing of beauty and performed well above my expectations (124/121). But it was just my luck that the stock bottom end didn't like all that power. Combustion chambers looked even worse that the tops of pistons.
I had a 08 dyno bought used with stage 1 cleaner, dripped on cover all the time, bought new FLHR in '11, got it bored to 103 and installed 204 cams and air cleaner, dripped all over, went to 107" powerhouse and decided to route to ground. I really don't subscribe to the theory that running a dry sump system low can cure the blow by out the breathers, (I did drill out drainback holes larger by the way).
I so much love the new bike.
#43
Bottom end. Crank and rods I was told.
But, whether OE venting or venting to ground, my TCs, have a sweet spot right in the middle of the dipstick(checked hot), (3qts at oil change), if filled above the sweet spot, they will use / blow oil until the level is back in the middle of the dipstick... Once at the sweet spot, the oil level will not change between 3-4k service intervals... Doesn't matter how the bikes are run...
Go figure???
All the drainback holes are stock, not drilled (per my Head Guy's and Builder's recommendation)...
#44
Received 3,930 Likes
I think a lot of folks might be getting hung up on just the build up on the pistons because of the visual aspect...
There are many reasons to run and EBS, beyond the build up-
There is an entire article on it HERE, along with dyno charts, but the short list is:
There is NO evidence that internal venting has any benefit in longevity, performance or economy.
There is overwhelming evidence that External Venting results in a cleaner engine, increased performance and economy.
- Oxygen rich air with an EBS, oxygen depleted air with stock venting.
- Cooler air is more dense, thus has more oxygen, thus produces better power and better MPG.
- External venting prevents sensors in the throttle body from getting gummed up.
- A biggie that most do not realize is that with an EBS you will have a stable tune. Lots more details on that HERE in #3.
#45
Nope, no sainthood needed. lol
While we are in biz to make money, we go about it a bit differently than most...most companies focus on what they have to do to make money (profit), we have a bit of a different philosophy.
Rather than focus on making a profit, we focus on making products that we believe in, products that will enhance a persons riding experience. It is our belief that if we do this correctly, then the natural result will be profitable.
Every single item on our website is a product that we use on our own bikes.
Nothing goes on our website (whether made by us or someone else) that we do not believe enhances our own rides, AND is worth the $ spent for the enhancement provided.
It does not matter how "profitable" selling item xyz may be...if we would not buy it for our own bikes, then it would betray the foundation we've built DK on...treat others as you would want them to treat you.
That said, I do not want the inside of my engine to look like the photo below, so I run, and have always run, an EBS on all my engines.
#46
#47
#48
Yeah I noticed that the motor is not stock.. Strong possibility there is some issue from build.. Notice the oil is around the edge of the piston? If coming in from the top it should have been better distributed in the chamber.. I'd bet it had a ring / bore issue..
#49
#50
