Anything else while heads are off?
#91
So reading up it sounds like rocker ticking can be from a lot of sources but one of them is a squishy lifter after the oil has warmed up. My ticking isn't that bad and I have checked the exhaust seal so is there any other benefit to replacing the lifters other than eliminating a minor tick and getting known valve movement? Does the play after warm-up cause pushrods to fail as well or something? Lifters seem like a cheap enough part to replace and it sounds like the more expensive ones don't get you much more bang so.....
#92
I was surprised to read that you never made mention of new lifters to compliment the build. Lifters are a maintenance type item that do require replacement over time. They wear like everything else... I also know that the TC heads are prone to rocker noise and have heard that the rock-outs do help. I would definitely at this point replace the lifters with S&S standards and set to .140".
No, your pushrods pushrods will be fine.
Your motor sounds very healthy. Nice job on the build.
#93
#94
#95
Ah yea, They are by far the choice of most builders here on the forum as well as my self. one and done... No worries. Standards are very good quality and can take the heat.... My well built Evo is as quiet as a church mouse and I sleep well at night.... lol....
#96
#97
I did do the rockouts and now have S&S lifters ordered. I will hopefully get them in next week as we are having some unseasonably warm weather. After the ice storm last night it is raining today. Temp in the 40s this week and 50s next week with rain so hopefully there won't be any salt on the road.
#98
#99
I got the lifters yesterday and took the push rods out today. I noticed before I took them out that there was some oil on the engine looking like it came from one of the rod tubes so have a set of push rod gaskets on order to replace these. Probably necessary anyway considering this is the second time I have taken the covers off since installing these gaskets. Hopefully will get the lifters in this weekend.
#100
