Andrews TW21 Cam question
I have the TW21 for my '06 Ultra (88 in) on the way and read that the cam only comes with 1 of the 2 outer cam bearing's. If so, which bearing is not included? Thanks for the help, couldn't find the answer in searching
Parts on the way:
TW21
S&S standard lifters
Torrington inner bearings
Cyco shoe kit
(using stock push rods, needed to address a slight rocker box leak anyway)
Thanks in advance for your reply's
Parts on the way:
TW21
Cyco shoe kit
yes, andrews only includes the ball bearing for the front cam in the cam plate. I'd closely inspect the roller bearing for the rear cam and as long as you dont see any pitting or gouging. I reuse that rear roller bearing. I have seen the front ball bearing go bad, never that rear roller though.
On a side note, ive ran my tw21 in 2 different bikes for a total of about 30k miles. Its a nice improvement over stock. Real noticeable midrange pull. Hope you like it. Im still running stock harley tensioners. Want to try to cycos next tensioner change
Just an update, the cams are in! I am very happy with the performance over stock, and a worthwhile replacement. HD should have put that cam or similar in at the factory. While I was into it I installed a Baisley oil pressure relief spring and oil pressure at an idle is up when hot. Now the bad news, it isn't a riding day, inclement weather
superderrick
Engine Mechanical Topics
10-05-2014 10:38 AM
