Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
from a 111 CID motor,i think your charts pretty much prove my point.HP/TQ that a VERY mild 95" TC or 96" evo could out do.very surprised scott from hillside hasn't chimed in,he knows where the 585 should be set,compression wise
You should sample a stock 111"! I'm not the one doing the arguing here, I'm simply commenting on first-hand experience of my bone stock engine and what it does. It's a touring engine, designed and sold by S&S expressly for that application. Their current V111/T111 has the same cam for the same purpose, with a similar low CR, as indeed does the touring T143". Mine is great and isn't 'flat', regardless of what anyone says. In the meantime I'll enjoy the ride with a smile!
