Can't leave well enough alone...
http://www.thevanillaworkshop.com/speedvagen-road/
Not the OG1 but the original Speedvagen frame with a variety of enhancements.
Robby knows I'm here for him and his money is no object
I was going to do the HD 110" cylinders/piston kit but they wouldn't make me one in black, before they grind of the edges of the fins. Original on my bike are all black so had to stick with them and do the 107" and it's every bit a spirited ride
robbyville (01-09-2017)
Deed is done! Taking the easy route, and keeping things all VeeTwin. Got the 107 cylinders from Kirby along with the various gaskets and such. He suggested a .040 head gasket to keep compression at 10.6-1 which he says is a sweet spot for my cams. He's also going to put the rings on the pistons for me, hopefully that helps.
Can't wait!
Can't wait!
Can't wait!
Can't wait!
Thanks and agreed! I think I get caught up in the marketing speak, "drop in" sounds so simple along with the lure of more cubes that it's easy to forget things like ensuring parts mesh well. Working with Kirby has always been easy and I know that he's recommending parts that will work with the ones he already sold and built for me. I was happy that he could do the rings since it will mean a few less tools to buy and confusion. Now I'll have to review the whole piston installation video, manual, etc.
Looking forward to it though.
You'll probably still have to clean the cylinders yourself. After doing two top ends and seeing the outcome of each I'm a fan of less is more with oiling the cylinders/pistons. This latest re-do I put a drop of oil in each ring land, spun the rings around in the groove(s) to lube them, and didn't even put any oil in the cylinder other than the coating of Marvel Mystery Oil that I applied during cleaning. A good piston ring compressor really helps with the installation. I got the nicest one as a birthday gift, it's made by Goodson. I could get by without it but. .it sure is nice to have.
You're completely right about the combination of parts being more important. I've seen sheets of 103's breaking 120hp/tq. Hard to believe as it isn't common but it can be done. Can't wait to see what mine does.
If the rings are on the pistons, that will eliminate the possibility of installing rings gapped for the front cylinder on the rear cylinder. If the rings are packed separately from the pistons, pay attention to insure the ring packs are installed on the right piston; they will be different.
Make sure you have the case bores closed off to prevent something from dropping into the crank case. I get those big sponges at the auto parts store for car washing and cut them to fit into the case bore with a slit to slide around the rod; lots of different ways to skin the cat.
Rumblin (01-09-2017)
