B lifters..Keep or swap?
Since I had it down I'd go-ahead and install GMR's or S&S standards and your good to go for another 40,000 miles !! I also like the SE adjustable s but S&S may have some quick installs as well.
Thanks for the replies.
I've been looking at the SE quick install.
A pit pricey but you usually get what you pay for. Also been looking at hylift johnson and the S&S standard lifters.
This bike is a daily rider barring snow,
Stage 2 is most likely all she'll ever see. Im all for quality parts without over killing it.
The 'B' lifters are the good ones, but I would consider replacing them while it's down...so you don't have to go in later. Some like the Hylift lifters, but everyone likes S&S.
I would look at the comp cams V-Thunder lifters. I went with these when I put the Andrews 48H cams in my Fat Boy...great reviews and price....these are the lifters people talk about when they say you can use small block chevy lifters
http://www.compperformancegroupstore...Code=LFTRHYREV
I'll probably just go with S&S standards.
Seems proven and not much different in price.
Was that "made in Mexico" thing ever clarified with the standards?
I use the Hy-Lift Johnson lifters from WFOLarry... http://www.larrysmotorcyclemachine.com/lifters.html
Top quality & very quiet.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
just got rid of the c lifters
pulled my 103 cylinder off to bore to 107, out original 96 cyls back on for a few months till all new parts are ready, put a set of s&s standards in the bike, what a difference, pumped up right away when bike started, did prime them up with oil can first. no ticking at all. all I hear going down the road is a whirling sound from the motor, Ill never use another set of Harley lifters again.
I did notice that the oil supply hole in the c lifter is smaller than an old set of b lifters I had in the garage. I didn't measure any of the holes, I think the s&s lifter oil supply hole may be slightly bigger than the b lifters
