Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I've got an 08 SG with a 96 ci motor that I'm putting a 107 kit on. I'm looking at putting a set of SE heads on it and was wondering if a set with the -11 casting number will fit. Have a chance to pick up a set at a reasonable price just not sure they'll work.
Wanting to put better heads on my 107. No one around here does port/polishing on Harley heads. Looking for SE heads that will bolt onto my 08 motor. Not sure if all SE heads will fit/work or if I have to go by certain years/casting numbers.
any twin cam head from HD will fit.now will they fit the rest of your build,thats the more important question.give us info on cams,t. body,ect you`ll be using.good chance porting your stock casting could be the best option
Looking at SE 255, Woods TW222 or Feuling 574 cam. Using stock TB with true duals and either Reinhardt or Basanni exhaust. 103 style air cleaner. Looking at using roller rockers, S&S pushrods and lifters. Possibly Feuling oil pump and cam plate, not sure yet.
