S&s 110 kit
We have several combinations.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
If you have the Power Vision, you don't need a new license; you need a tune. If your tuner has the Power Vision, he can sell you a license; saves you from buying the hardware/software but you still have to pay for the tune and you are locked to that tuner for future tunes which may or may not be a good thing. Either way, whatever the cost is to tune, that cost is in addition to parts and labor fore whatever you plan to build.
OK, so you have the Power Vision hardware/software which can be used to tune more than one bike, you just have to buy a license for each bike. You get life time maps, not tunes; a base map will get you close but a dyno is required to tune.
RSDUDA (01-10-2017)
Before considering gear drive cams you will need to measure the crank runout, most late model cranks are not applicable for gear drive as they generally land in the .004-.006" range.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
RSDUDA (01-12-2017)
Obviously a Dynotune would be the most accurate method but could get expensive if you changed anything, like pipes or cams for example, down the line.
I was under the impression that maps/tunes were based on results from Dyno testing, which if your configuration was the same as tested would bring you very close. An auto tune session would further fine tune your bike.
