Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Why do you say that? Just curious as I haven't had any issues and have used them on several bikes
They work just as they did 20 years ago which is part of the problem , James hasn't taken steps to use newer and better materials and gasket designs like HD or Cometic have. They aren't bad but they aren't as good as they could be.
One thing that harley does really well is gaskets. Is all I use if I can. Except for head gasket.
HD seals too!!! I HATE leaks and after enough times of Cometic and James wasting time and money for me, it's OEM only now. Never thought I would ever say that,,,,,,but I did.
