I need clarification on bore size...
Old 01-10-2017, 04:11 PM
jon loder's Avatar
jon loder
jon loder is offline
Default I need clarification on bore size...
I'm rebuilding a '83 FXWG. The Cylinders are Zodiac Enterprise "big bore."
I just dropped them off at a local (very reputable) machine shop for honing. I asked them to call me with the bore size when they had a chance to mic. He just called me back with 3.657". We had a short discussion on bore sizes. He assured me that "thirty over" means additional diameter, not cutting thickness. I always thought that it was the other way.
So... it sounds like I have 3-5/8" bored 0.030 over which is 3.625" plus 0.030" for a total diameter of 3.655". (allowing a couple thousandths for hone.
Is that correct? I was always under the impression that "thirty over" meant adding 0.060" to the bore.
I need to order my rings and I would like to have a little higher confidence level.
Old 01-10-2017, 04:56 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,785 Likes on 3,301 Posts
Your local shop is correct...
jon loder (01-10-2017)
Old 01-10-2017, 08:19 PM
Mike Lawless's Avatar
Mike Lawless
Mike Lawless is offline
Yep. What hotrodfatboy said. You are .032" over.
Old 01-11-2017, 06:11 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
.030" oversize is what you have.
If .060" o/s, that would have you at 3.685".
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 01-11-2017, 12:36 PM
jon loder's Avatar
jon loder
Thanks for the confirmation, guys. I've had several engines bored from a KZ-400 to big block V8's and everything between. I guess this is the first time that I've actually determined an existing bore to match rings for. I've had the same misconception the whole time.
NELS
Shovelhead
01-01-2018 01:18 PM
GfromAlberta
VRSC Models
01-07-2012 08:55 AM
Capt_Locutus
Exhaust System Topics
05-13-2009 02:05 AM
pear69
04-07-2008 12:41 AM
supr2nr
Ironhead
02-15-2008 09:10 PM
Quick Reply: I need clarification on bore size...
