Special tools for Rocker Base upgrade & Lifter Replacement
I'm pulling my rockers for Rockout installs and putting in new lifters. I have most tools but do I need anything special to do this job? I think, in order to torque the bottom pushrod bases, I need long allen sockets? I have normal length ones.
Then for the rocker bases, I've heard I need a torque extension, or converter, I think it's called to get me in under the frame to tighten those bolts and torque them? I have 3/8" crowsfoot wrenches, but not sure those are long enough (?).
Thanks for the help in advance.
"Torque adapter" is what you're referring to...
https://www.amazon.com/Stanley-J5116...orque+adapters
__________________
NO, they DON'T all do that!
Also on amazon.com...
I would if I was doing cams likely, though I've heard people like them for that application as well. But seeing as I am leaving the original cams in for now, and pushrods, I'm gonna put these in and then if I do cams it later, I'll decide whether or not the new ones are will be premium or not. Have you done lifters before?
