09 electra glide starter issues??
Hey guys I'm trying to tackle an issue that showed up late last season
for example -first ride of the day (cold engine) - starts and runs perfect - drive for 10 minutes and turn off the bike to do some banking or whatever -when I try to start after 2 - 3 minutes of sitting (still hot) I get this wicked crunching / grinding noise -
I then bump the start button a few quick times and it turns over and away I go
any ideas? I'm going to pull the primary cover and inspect but if anyone has any insight and can point me in the right direction that would be great
09 electra glide classic 96 CI
cheers
cheers
Ya Ill check the splines out - just started doing it - maybe 4 or 5 kick backs tops - been reading up on the comp seems like it happens alot on the 09's / 10's
if you happen to have a part number for the SE kit that would be helpfull -
according to the HD site the part number is 42200064a - however its specs a trike??
The part you need should be part number 40100061 and it should come with the new rotor which does have to be used for it to work. Also requires separate purchase of part number 11100088, which is an adhesive kit to mount the oiler on the inside of the primary cover. If it has only kicked back a few times the clutch hub is probably fine, I normally see them damaged whe the problem has been going on for a while, but still good to check its since it will be off the bike anyways
