Twin Cam 88" build-Cam questions
Currently building up my 2006 TC 88", currently has a S&S cam plate and oil pump upgrade to replace the stock tensioners and increase oil flow, my question is when ordering my cam, do i order a cam that is for a 96" TC motor since i upgraded the cam plate to the 07+ oil pump and plate?
REW13 (01-22-2017)
Sure it is. Don't confuse the guy.
It's a 2006 TC88 in a touring model. As I said, the inner cam journals are smaller than the inner cam journals on an 07 and up bike. He needs conversion cams.
I went with Andrews 26N conversion cams and am happy with the results.
What are your performance goals?
What exhaust are you running?
A/C?
Tuner?
I was looking for more torque in the bottom to mid-range. I went with the cams mentioned above, SE A/C, TTS Mastertuner and a V&H Pro Pipe. If it ever stops raining in Northern California, I plan to have a proper dyno tune done.
Lot's of good advice on this forum.
Garrman
A/C?
Tuner?
Garrman
