Bad Piston, Losing Oil...
bad tune or bad oil ???
as soon as i pulled up at the house , dropped all the fluids , which was so thin , looked like water running out ...
added some "real oil" ...has never sounded or run that hot sense !!!
good luck with the New Motor
10-4 !! we have a 14 SG also ...bought it new ...about a 60 mile trip home...had to stop twice as it sounded like it was going to come apart ...over heating etc...!!!
Based on your description, most likely they only needed to install cylinder and piston kit. Add oil and couple gaskets.
Mechanics sometimes install parts "just in case". Most likely crank and oil pump didn't need to be replaced.
It is possible that they didn't replace crank and oil pump, but charged you. Did you ask for old parts back? Always do that and get old parts.
If it was paid for under an extended service plan, I don't think he can get the parts back. After all ESP paid for them..
It wouldn't surprise me if it needed a crank..
