Twin Cam Timing & "punch marks"? - Page 2 - Harley Davidson Forums
P
Thread Tools Search this Thread
Old 02-16-2017, 08:09 PM
DianneB DianneB is offline
Senior Rider
Quote:
Originally Posted by bwoltz View Post
The marks should on the inside side of the gears... Looking at the rear cam you should replace the rear bearing with the roller bearing replacement...
Bearings already changed. No marks anywhere on the cams except those pictured, NONE!
Old 02-16-2017, 08:13 PM
bad tappets's Avatar
bad tappets bad tappets is online now
Senior Rider
I just pulled the stock cams out of my '06, they did not have dots. They had lines, and not the line the OP shows in his photos. Should be one distinct line on each cam each toothed gear.
Old 02-16-2017, 08:23 PM
RIPSAW's Avatar
RIPSAW RIPSAW is online now
Quote:
Originally Posted by DianneB View Post
That makes sense, particularly if they are after-market.
Think they are Feuling
Old 02-16-2017, 09:21 PM
bwoltz's Avatar
bwoltz bwoltz is offline
Well I was wrong.. Those are stock cams and the marks you are lookin' at are correct.
Here is a set of 02s out of my 02 RKC The marks on the ends correspond with marks on the teeth and they are in the right position for the missing tooth on the outer cam gear spline..
Old 02-16-2017, 09:22 PM
djl's Avatar
djl djl is offline
I would install them with the squiggly lines pointing at each other in the same plane.
EDIT: As shown above in the bwoltz post
Then slip the sprockets on and see if the dots on the sprockets line up as shown in one of the attached photos. If the sprocket dots line as shown (picture shows dots, not squiggly lines) then the dots on the cam sprockets should line up as shown in the other picture which would be TDC on the rear cylinder which is the #1 cylinder. I would try that and see how things line up.
Twin Cam Timing & "punch marks"?-cam-sprocket-timing-marks.png   Twin Cam Timing & "punch marks"?-outer-cam-timing-marks.png
Old 02-16-2017, 09:37 PM
Senior Rider
Yup, those were the lines I was talking about.
The Following User Says Thank You to bad tappets For This Useful Post:
bwoltz (02-16-2017)
Old 02-17-2017, 06:22 AM
Senior Rider
Hey man, THANKS! That is reassuring.
Onward and upward!
Old 02-17-2017, 06:46 AM
Back-n-Black's Avatar
Back-n-Black Back-n-Black is offline
Should of taken a picture when you were in the disassembly stage... But IMO the marks you are point to are the ones you line up.
But...I'm not a mechanic
Old 02-17-2017, 11:47 AM
Lunchboxx Lunchboxx is offline
One Of The Regulars
When I did my 01 TC88 it looked like this picture
Quote:
Originally Posted by QC View Post
Were there any dots like this on them?
Old 02-17-2017, 12:31 PM
bwoltz's Avatar
Quote:
FWIW those are aftermarket cams..
P
Thread Thread Starter Forum Replies Last Post
No Timing Mark on Pinion Gear: 1993 XL1200 TStephen Sportster Models 17 12-02-2016 03:43 PM
Cam Gear Alignment Issue TStephen Engine Mechanical Topics 5 12-02-2016 02:25 PM
breather cam timing in 1998 FLHTCU marktruckee Evo Classic Models 10 06-28-2016 02:54 AM
Cam chest assembling questions '80 XLS halmc Ironhead 7 06-27-2009 11:21 AM
Cam tensioners/cam plate pics Neil Touring Models 18 10-14-2008 11:22 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
