Twin Cam Timing & "punch marks"?
Old 02-16-2017, 07:09 PM
DianneB's Avatar
DianneB
DianneB is offline
Originally Posted by bwoltz
The marks should on the inside side of the gears... Looking at the rear cam you should replace the rear bearing with the roller bearing replacement...
Bearings already changed. No marks anywhere on the cams except those pictured, NONE!
Old 02-16-2017, 07:13 PM
bad tappets's Avatar
bad tappets
bad tappets is offline
I just pulled the stock cams out of my '06, they did not have dots. They had lines, and not the line the OP shows in his photos. Should be one distinct line on each cam each toothed gear.
Old 02-16-2017, 07:23 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,540 Likes on 3,792 Posts
Originally Posted by DianneB
That makes sense, particularly if they are after-market.
Think they are Feuling
Old 02-16-2017, 08:21 PM
Max Headflow's Avatar
Max Headflow
Max Headflow is online now
Received 5,252 Likes on 3,626 Posts
Well I was wrong.. Those are stock cams and the marks you are lookin' at are correct.
Here is a set of 02s out of my 02 RKC The marks on the ends correspond with marks on the teeth and they are in the right position for the missing tooth on the outer cam gear spline..
Old 02-16-2017, 08:22 PM
djl's Avatar
djl
djl is online now
Received 2,030 Likes on 1,498 Posts
I would install them with the squiggly lines pointing at each other in the same plane.
EDIT: As shown above in the bwoltz post
Then slip the sprockets on and see if the dots on the sprockets line up as shown in one of the attached photos. If the sprocket dots line as shown (picture shows dots, not squiggly lines) then the dots on the cam sprockets should line up as shown in the other picture which would be TDC on the rear cylinder which is the #1 cylinder. I would try that and see how things line up.
Attached Thumbnails Twin Cam Timing & "punch marks"?-cam-sprocket-timing-marks.png   Twin Cam Timing & "punch marks"?-outer-cam-timing-marks.png
Old 02-16-2017, 08:37 PM
bad tappets
Yup, those were the lines I was talking about.
Max Headflow (02-16-2017)
Old 02-17-2017, 05:22 AM
DianneB's Avatar
DianneB
DianneB is offline
Hey man, THANKS! That is reassuring.
Onward and upward!
Boris Matilda (03-07-2022)
Old 02-17-2017, 05:46 AM
Back-n-Black's Avatar
Back-n-Black
Back-n-Black is offline
Should of taken a picture when you were in the disassembly stage... But IMO the marks you are point to are the ones you line up.
But...I'm not a mechanic
Old 02-17-2017, 10:47 AM
Lunchboxx's Avatar
Lunchboxx
Lunchboxx is offline
When I did my 01 TC88 it looked like this picture
Originally Posted by QC
Were there any dots like this on them?
Old 02-17-2017, 11:31 AM
Max Headflow
FWIW those are aftermarket cams..
Quick Reply: Twin Cam Timing & "punch marks"?
