FM 107 vs Revolution Perm. 107
Old 02-19-2017, 12:23 PM
jmd897's Avatar
jmd897
jmd897 is offline
I did but 110 the crankcase needs to be open. Yea prestige was one of the customs place I visited yesterday.
02603SEC's Avatar
02603SEC
02603SEC is offline
Drop it off with Prestige. I'll get you back to the boogie down if you want.
Old 02-19-2017, 12:24 PM
02603SEC's Avatar
02603SEC
02603SEC is offline
What bike do you have.
Old 02-19-2017, 12:28 PM
jmd897's Avatar
jmd897
jmd897 is offline
07 Fatboy 96b engine
Old 02-19-2017, 12:29 PM
jmd897's Avatar
jmd897
jmd897 is offline
With prestige camwork included? How much is your total?
Old 02-19-2017, 12:39 PM
02603SEC's Avatar
02603SEC
02603SEC is offline
107 kit, cams, oil pump, head work, dyno under 5k cash. I already had a Powervision, exhaust and high flow AC. Yes in a 96" you can only go to 103" without opening cases. I considered a 110" tire shreder kit for my Breakout, but heat was a big issue with them, and a properly done 107 will run right past it.
Old 02-19-2017, 12:43 PM
jmd897's Avatar
jmd897
jmd897 is offline
Yea they said 107 dont need to open case. The headwork did you get compression release?
jmd897's Avatar
jmd897
jmd897 is offline
What cams you using?
Old 02-19-2017, 12:48 PM
02603SEC's Avatar
02603SEC
02603SEC is offline
Nope, 107 is good to go as is. I have a 2017, so it has auto comp. releases stock. I can't remember what cam Vinny said he would use, he knows what I want so I trust his choice.
Old 02-19-2017, 12:50 PM
jmd897's Avatar
jmd897
jmd897 is offline
Yea i spoke with Rich too and samw thing. He said feuling reapers will be the cam. I would need compression release since im going to a 10:5:1 ratio on the compression.
Quick Reply: FM 107 vs Revolution Perm. 107
