Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Yes, it was a Fueling cam. X2 on the compression releases with 10.5 to 1 that or find a place to mount a second battery. I have deal with Vinny, Phil and Anthony since they were Prestige HD in Rockland county, Phil and Anthony are the only two techs I fell comfortable tearing apart my brand new bike. I was serious BTW, if you need a ride home, I am 5 min. from Elmsford in Dobbs Ferry.
I think the plan is a 107 kit with feuling cams, adjustable pushrods, high flow oil pump, stage 2 or 3 heads, compression release. I got a big radius 2 into 1 and heavy breather. They said no need to change it. Also throttle body is an option. Plus dyno about 4k-5k.
I have the BR 2 into 1 and heavy breather elite, go stage 3 so you have room to grow if needed. Not doing throttle body because I think you lose to much low end, may do bigger injectors in the future.
Thanks for the input. The dyno at Prestige is crazy. Rich showed me a demo and I was like wow they kept the bike really cool for pushing it to max performance. Name is Juan btw.
I did but 110 the crankcase needs to be open. Yea prestige was one of the customs place I visited yesterday.
No case work required for the HD110 kit; that's why it is called a "drop in" kit. One of the better offerings from HD; many on the street making good numbers with no issues.
I just read through the SE catalog and it looks like you can't go past a 103" with a 96" engine.
