FM 107 vs Revolution Perm. 107
#61
#62
Yea but all together most builds (whether its the dealer, Hillside, or Prestige)parts and labor(including a dyno tune) runs about $3k-5K depending on the build. yea if I keep the heads stock I save $1000 but I would limit my cam selection.(No high lift) Honestly I would do it myself but its not a brake job or draining the oils. Its taking out pistons, cams, cylinders and a fuel tank and praying you don't break a bolt or put things on the wrong way even with a service manual which I have. I don't like towing my bike to a repair shop to have them say I told you so.
#63
Originally Posted by prodrag1320
just my opinion,but 5K for a 107" build is nuts.you can do a mild 124" for that
jmd897 (02-21-2017)
#64
#65
As a reference we charge $2199.00 for the complete 107 kit installed and professionally dyno tuned; turn key. Options include our CNC ported heads which run $879.00-995.00, you will need to upgrade the clutch with a heavy duty spring and/or lockup which runs $30.00-285.00, you need the appropriate EFI tuning product such as Dynojet Power Vision $399.00, and an exhaust and air cleaner that will support the appropriate Hp/Tq. We also offer a wide range of options for those looking for more horsepower or something different, with dozens of configurations from mild to wild. We can do the build in a day and a half, this includes a full dyno base evaluation, complete engine build, comprehensive dyno break in and professional dyno tune. The bike leaves turn key; ready to ride. Customers ride in or ship their bikes from all over the country, FM generally rolls out 3-4 bikes per week. Country Inn & Suites is just down the street from us and they offer a Fuel Moto group rate, we offer shuttle to/from the hotel as well.
There are assorted dyno charts of some of our builds here https://www.fuelmotousa.com/p-33193-dyno-charts.html
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
jmd897 (02-21-2017)
#66
I can save about $500 from that $3000 by working with what I have, no kit; however, Fuel Moto does offer some slick packages as does Kirby, particularly his "specials". WRT the 124, I am pretty sure Kirby is talking built 124" motor. Customer pulls the motor and sends to Kirby; Kirby builds motor (note he referred to a "mild" 124) and returns the built motor to the customer. Customer installs motor and is responsible for upgrades such as exhaust, clutch, carb/throttle body, fuel management and tune.
#68
The kits are the way to go but like others said when it gets to the dyno the finger pointing can start and then it's not a good place to be.
#70
