Lifter or valve clicking after battery replacement
Old 02-19-2017, 03:48 PM
Kirbylynn1's Avatar
Kirbylynn1
Kirbylynn1 is offline
Stage I
Default Lifter or valve clicking after battery replacement
I replaced the battery on a 2008 Street Glide. After starting bike , there is now a clicking sound when the motor is running. Sounds like a lifter or valve. I rode earlier the same day, 40 miles, with no clicking and I have never had clicking any time before that. I am thinking the battery has nothing to do with the noise and it's just a coincidence that these 2 things happened at the same time. I tried to charge the battery before replacing and tried to start the bike maybe 10 times without it starting. Could I have drained the hydraulic fluid from somewhere?
Old 02-19-2017, 05:49 PM
ROCKOUT Rocker Products
ROCKOUT Rocker Products is online now
Sponsor
Received 1,628 Likes on 1,176 Posts
Sounds like a lifter may have bled down from all the cranking without starting. It should pump back up with some run time.
If not have a look around my website, might be just what you need
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Shovelhead60
12-02-2017 11:45 AM
Varooom
03-17-2016 08:28 PM
Jamman718
10-04-2014 07:34 AM
ironmike41
11-14-2013 08:04 PM
tumbleweed883
12-06-2009 07:32 PM
Quick Reply: Lifter or valve clicking after battery replacement
