Plans for 107"
Plans for 107"
So I am in the planning stages for a budget 107 build on my '10 FLHTK.
I would like some input on the component selection as well as overall combo.
I already have a FuelMoto air cleaner, SE 255 cams, Power Vision, and D&D slip-ons.
I intend to retain what I already have and use the following for the 107 build.
Hylift-Johnson 2313SE Lifters
Cometic 4.060 .040 thick head gasket
Big Boyz ported heads
Jackpot ceramic coated head pipe and stainless full size crossunder. (Budget allowing)
AMS Moto big bore pistons and cylinder boring (KB pistons, Hastings rings).
I understand I am going to have to be careful about cranking compression.
Big Boyz calculator comes up with 208 psi with a 0 deck.
Is this pushing it? I believe the pistons can tolerate some machine work to reduce compression if required. I know FM gives this option with their CP pistons.
Please let me know your thoughts.
Last thing you want to do IMO is put more pressure on a crank with run-out issues.
If more than .003" run-out, reconsider your strategy.
In a 107" touring build, an Andrews 57, or CR .575 would be better choices than that emission-oriented 255.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
the 255 is a stock trade up, low compression cam and will fall flat on it's face way before 5k. No sense in doing heads if your gonna use that cam. With chain drive you will be fine and yes the moco upped the run out to .012"... 208 ccp is very high and you will have problems tuning the motor with the 255. As said a cam with 38-42* will suite the build good and will carry out a lot further... A woods TW-7H would be a good cam for that build with real good low and mid torque but will still carry up over 5500 rpm set at 10.0-10.2:1 COMP.... But most are using the Andrews 57 cam....
Make sure you have a reasonably good tuner to tune the bike.
