103" jugs on a 96"? What do I need?
So my buddy has a '15 SG that he's bumping up to a 110"He said he'd make me a smoking deal on his takeoffs so I could go to 103".What all is involved in doing this?What all parts do I need to get from him?I can do all the work myself,and am considering cams while I'm at it.Can I use my throttle body assy.?Thought about getting a tuner as well.Any advise before I start spending $$$?
Mines an '07 Softail Custom.
This is kinda what I was hoping for....easy swap.So as far as a tuner,could I just theoretically set a tune for a "103 w/ V & H pipes and open intake",or would I have to do anything special?Thinking a PV tuner,and Target Tune.What about the throttle body?Would they be the same or would/should I just use mine?
I do want to change cams.......now of course....which cam to run?I have dabbled in the numerous threads on this very topic,and am still undecided.
Assuming 85cc chamber, and a .030" head gasket,(10.0 cr) you'd be in good shape with an Andrews 57, S&S .570, or a Wood 6.
You could, however, also include a set of good cylinder heads, and a port-matched intake manifold, to up the power.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
As Scott suggested, I'm not too sure about the Andrews or S&S cam but I do know that the W6 carries a real nice curve and carries it out very well to 6k. The attached is in an 80"er that Scott built. I know it's not a 103"er but i'm only posing it so you can see what to expect from the W6 cam...
SORRY, but I'm having a problem Finding the dyno sheet, when I do I will post it....
