Cam Choice for 107" build ??
You can remove material from the dome, but .180" is the minimum wall thickness on that.
Once machined it then needs to be cc'd.
Wonder why they'd suggest all that work, when a Wood 6, or 5-6, Andrews 57, S&S.570, CR.575, all thrive at 10.0-10.2 cr, which is at/near the squeeze on a flat top/107"/OE 85cc chamber/.040" gasket.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
BezerkoBob (03-02-2017)
Scott
Scott
Maybe the OP can shed some light on that one.
Scott
Scott
I'm considering the 107"/57h/torque heads/.040 gasket for my 96" dyna. I don't really run it out past 5k rpms much, really just looking for torque. So question is would the stock throttle body/fuel injectors be sufficient or would i need something bigger for this set-up?
Your OE t/body and injectors will work just fine.
I'd suggest at least, a 1.900" intake valve, and one of our Super Stock valve jobs on your heads.
Strong, snappy combo.
3 of those semi-similar builds going on here at this time.
Scott
Scott
Scott
Seems such a waste of time and money to Mill the Pistons and detune when you can just add the woods 5-6 or the CR 575 and have a better all around performing machine... You obviously had questions and were looking for advice when you posted so I would listen to what the pro's have said.... But it is your money.......
