Cam Choice for 107" build ??
Looking for some cam selection advice for a 2011 touring bike. Sent the 103 motor to Roeder's in Ohio for a bottom rebuild and boring cylinders to 107 using Wiseco forged pistons. The heads are getting a valve job but probably no porting at this time. We talked about using Andrews 48 cams but with those pistons and a .045 head gasket compression will be a bit high. Builder talked about relieving the pistons a tad to get compression where it needs to be or am I better off leaving pistons be and using an Andrews 54 or 57. Bike has S&S slip ons and cat is gone. Ultimate goal is torque down low, reliability and a smooth motor. Any advice out there would be appreciated.
When I get the sheet I will post it. Weather is still iffy and the roads are a mess so I probably won't pick it up for bit.
