Dip in power curve?
Dip in power curve?
Hi everyone, a few people suggested I post here to try to figure out a strange dip in the power curve at 2900 RPM on my 98" big bore. The build has the following:
Just got my bike back from Suburban Motors in Thiensville, WI. Bike had 53k on it, and a nice running stock/stage 1 88". The original plan was to go with a cam swap to eliminate the chain drive cams and install a 2 into 1 pipe. Then one thing led to another. Ended up doing the 98" big bore high compression "Street Stomper" kit they offer. It consists of the following:
Bore stock jugs
Custom forged Mahle pistons
S&S 585G cams
45mm Mikuni carb
SE HD clutch spring
Adjustable pushrods
Daytona Twin Tec ignition controller
Ported & flow benched heads
Compression releases
1.9 Intake valves
10.5:1 C/R
Rinehart 2-into-1 full exhaust.
I'm wondering if it has anything to do with the cams or the exhaust?
Bore stock jugs
S&S 585G cams
45mm Mikuni carb
SE HD clutch spring
Adjustable pushrods
1.9 Intake valves
10.5:1 C/R
+1 The Rinehart 2:1 isn't much better than slip ons, but it looks good. You might want to look at a Thunderheader or a Fat Cat if you want performance. That is a pretty high compression ratio for a 98" with 585 cams, but I wouldn't think that would give you issues.
Thanks for the quick replies, you guys rock! I haven't had a chance to ride it due to cold and salt so we'll see how it is going down the road. I did notice when revving it hard it does blow a little black smoke but no hesitation or stumbles. The builder was pushing a FatCat but it was too loud for my likes.
What is the ccp of that engine?
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
