259e cams in a 2012 103 street glide
Not going with the street one. Found a new non-street one and going with that. I have heard that the 204's with 1.7 rockers works real nice as well.
I would go with the andrews 57 and advance it 4 degrees. Basically the same specs as the 204, but with more lift than the 204 with the SE rockers.
In all seriousness, I am keen on the idea of a map being available for the SE cam and it being more or less plug and play. It will be probably much later in the year when I can have this thing dyno tuned as I have been spending money like water on this bike, and I have only had it a few weeks. As far as if I were to go with the Andrews cam, I am assuming I need a different key way or something to advance it 4 degrees?
Yes, but would it come with a Screamin' Eagle sticker?
http://www.ebay.com/itm/Andrews-Cran...tW3hCD&vxp=mtr
rblahetka (03-16-2017)
I didn't have much luck with the canned map Harley loaded for the 204 with the old super tuner. On a hot day it would pre-detonate like crazy. The only way I got it fixed was to take it to a good local tuner. I am not saying it wont work for your application only that it was a PITA for me. I have heard the 204 can be a bitch to dial in.
It doesn't usually get too crazy hot here in Illinois, but still I would like to avoid pinging and making the bike unreliable. I have also heard the 204 can be hard to tune as well. As far as the Andrews came with the 4 degree gear, would I be in the same possible boat with the pinging? I like the idea of not having to by rockers on top of the cam.
rblahetka (03-17-2017)
I ended up pulling the trigger and ordered the 57H's last night. I am going to order the 4 degree gear as well. From the beginning I wanted to avoid using adjustable push rods and planned on pulling the valve covers to install the rock out kit while I was at it. So, I have the cams coming, rock outs, cam lube, and the puller and press tools for the bearings. Now the question is, what gasket / bearing kit do I get so I am sure have everything so I can hit the ground running? I am hoping to tackle this next weekend.
http://stores.ebay.com/Falcon-Sales-...p2047675.l2563
