Changing Rocker Boxes
I have a 2003 Fatboy and want to change the rocker boxes. It seems like an easy job. Remove the gas tank, slowly loosen the 6 bolts in the reverse order of the torque pattern, change the boxes and gaskets, tighten the bolts to proper torque specs and pattern, re-install the tank. Am I missing anything? This seems like a relatively easy afternoon job.
Here's a pic...
If you're removing the rocker supports I may have a suggestion for you
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Unfortunately, I recently took care of the tensioners. I wish I had bought the new boxes 1st. I will be doing top and bottom boxes, and it sounds like I am in for more of a project than I thought.
I paid for the tensioners because I upgraded cams while I was there. A BB kit is in the future as well but want to change the rocker boxes now because they are in really bad shape. The BB kit is probably another year away.
Received 4,922 Likes
