1200 conversion pro tips
the small 883 ports are not really the issue,its that the 883 chambers are a lot smaller than 1200 chambers and unless you use dished pistons or open up the 883 chambers,you`ll be running a lot more compression than you want (unless your setting up a very high compression motor,& in that case,you shouldn't run a OEM cast piston)
Wiseco offers a reverse dome piston that maintains OEM piston weight, and OEM compression, under the 883 chamber.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Edit: I would keep the 883 heads in case you decide to do a performance build. Those heads are nice to work with if you decide to have them reworked. Also that allows you to keep riding your build whale parts are off getting reworked.
