Upgrade to 103 or 110
I want to punch my 08 96ci to a 103 or 110. I hear some cons about going to a 110 from a 96, SOME people says its pushing it a little for ,but people do it all them time. I would like to hear the pros and cons from people if some one could lighten things up for me. I sure would appreciate it .
Thank you.
Thank you.
Thank you.
Thank you.
Thank you.
Thank you.
If going to a 103", then may as well bore to 107". Same cost if using Wiesco pistons.
If considering a 110", that requires case boring, then a 117", or 124" is all the same labor, and the power delivery is much more.
Not pushing it at all.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
Depends on how much HP/TQ you think you want/need.
You might want to do a cost comparison between a simple 103 ci upgrade with and ANYTHING larger. Several shops (Headquarters, T-Man Performance, etc. have done all the planning and putting together all the parts so you get the most bang for the buck...so to speak.
You can get a good 100+ HP/TQ 103 upgrade for $2,500 and up depending on your choice of exhaust.
Good luck with your upgrade.
Jim
Jim
