Crankshaft Repairable?
Old 05-01-2010, 10:16 AM
code3dude77's Avatar
code3dude77
code3dude77 is offline
Default Crankshaft Repairable?
I was wondering if anybody might know how much out of true until you can not repair a crankshaft from an 08 Dyna.
What happened is my clutch basket broke and a large piece wedged between the primary chain and the clutch sprocket causing the chain to seize while the motor was running and tweaked the crankshaft (amongst pretty much destroying everything in the primary). I pulled the motor apart and split the cases. To the naked eye the shafts don't appear to be bent. The plug holding the two flywheels together has clearly shifted. That can be seen and felt.
I was told by a local guy that has experience with crankshafts that he has the capability to true and tig a crankshaft up to .020" out of true. When the crankshaft was in the motor it had to be at least .1" out of true cause you can see it move with the naked eye.
So the real dilemma is buy a used crankshaft that hasnt been tweaked for $250 then have it trued and tigged for another $150. Or do I send mine in for repair from somebody like darkhorse or Revolution Performance who possibly has the capability to repair such a tweaked crankshaft like the one I have?
P.S. If you plan on running a lot of torque (125 like mine) and plan on riding it hard, spend the extra money on a aftermarket clutch basket before you have to replace it along with a motor tear down and whole primary.
Old 01-28-2015, 04:21 PM
1BMF's Avatar
1BMF
1BMF is offline
Default Shaft damage results?
How did you make out with these shafts being badly damaged? Having a similar situation myself
Old 01-28-2015, 04:57 PM
daveblank's Avatar
daveblank
daveblank is offline
I don't know if this is an option, but there is a shop that list crank/rods on Dallas Craigslist for either $100 or $150 on a regular basis. I don't know how much shipping would be.
Old 01-28-2015, 07:22 PM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
might just want to go with a S&S 4.375" unit & a 107" kit.never have to worry about it again
Old 01-29-2015, 05:16 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
If you have the dough, an S&S crank is the way.
Full supported wrist pin with their rods, vs the OE taper-tops.
Forged steel, true, rock solid.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
07streetbob07
04-25-2018 09:02 AM
Whitey22
Shovelhead
09-23-2015 06:25 PM
GlobeWarmer
10-13-2014 11:49 AM
code3dude77
Exhaust System Topics
05-11-2010 08:41 AM
JosephGarcia
03-20-2009 02:35 AM
Quick Reply: Crankshaft Repairable?
