Knock knock knocking in carb
I just finished (literally 20 min ago) a hydraulic tensioner upgrade to my 02 FLHT. While I was in there I went ahead and upgraded to Andrews TW37 cams and inner cam bearings. I did not pull the heads. I replaced the push rods with adjustables push rods. Everything went reasonably well. I cranked it up and after some lifter ticking (that freaked me the F out) for about 1-2 minutes, everything quieted down.
It seems to be running fine except I hear some knocking in the carb. It's not lifter knock and I seem to have good oil pressure (engine light is not on). It's more like a brass hammer lightly tapping a peice of really hard wood like solid maple. It only does it at low RPM. As I increase the revs up past 1500 if fades out as the engine comes up. I thought it might me my air cleaner. Thinking it was loose, but I took that off and it is still doing it. I even put my ear up the the carb and it is definatly coming from there. The knock might have even been there before the upgrade an I am just being hyper sensitive after digging so deep into my motor. Carb is an S&S -E for what it's worth. Any ideas?
Here is a link to a video of the knocking. It's actualy not anywhere near as loud as the video makes it seem. http://www.youtube.com/watch?v=N4xFEVkYgII
Correction ---- The knock is back... Old post>>> I readjusted all the pushrods and found that my front exhaust was just a tad loose but not much. I let the lifters bleed down for an hour before firing it up. When I first cranked it up I still heard the knock but not as bad. I let it idle a little while until it was somewhat warm (5 min or so) and the knock is gone. I think it just didn't have enough time get oil everywhere in the top end before I freaked out.
I thought about deleting this post since no one responded but maybe it will help somebody else out who is going through the same thing I did and maybe keep them from loosing their mind.
Thanks for the reminder! The knock is still there. I did NOT pre lube them before I put them back in and I know better. I'll bet it is the lifter(s) is where the noise is coming from. I am going to recheck with a long screwdriver to my ear tonight.
Same sound
So I have a similar sounding knock. Is coming from inside the carb. Side note carb is an S&S Super E. With a stethoscope it sounds like it's coming from the bottom of the butterfly. Did you ever find a solution?
Rickity (08-03-2019)
When you re-ringed, were the cylinders bored and new pistons fitted or just a hone and re-ring? Depending on miles, if the fix was a hone and re-ring, cylinders bores may not be true; ring installed upside down, poor piston to cylinder fitment as well as pushrod/lifters. Did you check compression or leak down before the re-ring?
