Cam Needle Bearing Orientation
I am putting new needle bearings into my 99 Dyna, 88inch twin cam. I am thinking I might have put them in backwards. Should the letters face the crank or cam plate?
I have them installed now so that I can see the letters; facing the cam plate. If that's not right should I remove these and buy some new ones to install the right way?
Iman,
I don't believe it makes a difference which way they go in.
They are not directional.
But for future reference...
If you look at the bearings, you'll see one edge, of one side of the outer race is more rounded than the other.
This rounded edge is to guide the bearing into the hole, making the installation easier.
I don't recall which side the letters are on (the flat side, or the rounded side).
