Explaining How Cams Work and What the Numbers Mean, Parts 1 & 2
#41
I originally compiled all that information from various sources back around 2006 and first posted on Road King Riders Forum Interesting to see it circulating on different forums
http://forums.delphiforums.com/n/mai...gid=2020890016
Good read on Corrected Compression Ratios and Squish
http://www.*****************/forums/...am-timing.html
You took the initiative and posted a wealth of information on all the technical information related to cams to help people understand more about them, and you gave due credit for each source you obtained your information from and did not claim credit. Kudos to you!!
I'm having fun going through all of that info. Thanks a bunch!
#43
Would anyone have a perspective on a tc88 with 97 ci jugs, 10:1 pistons, flowed heads and S&S gear drive cams in a softail? I'm just wondering if that cam is a good match for the other parts
#45
looking for a good set up
just starting to work on my 2005 twin 88 injected wide glide going with S&S big bore kit 100cu with gear drive 585 easy start cams no head work yet upgrade oil pump and cam plate dont know which fuel control mod to use have Vance and Hines big staggered with crossover 55,000 miles will go S&S crank if runout is bad or if you recommended after teardown. what else should be done or is needed to complete having a fun ride? thanks for your time..
#46
is this the right place to ask about the cams in my TCb Fatty, theyre getting pretty noisy, which is a bit worrying being where i am.
If i use an additive next time i change the oil will it quieten them down a bit
this is the one I've been told is ok
http://www.everglideoil.com
#47
I would recommend you talk to the manufacturer of everglide before using it
I my self am curious about trying it, though I'm happy using my AMSoil synthetics
what oil are you using in the tranny at the moment anyway?
#48
i know what its like though when you find something you like though.
using a an 80-90 in the tranny
#50
Great post! Thanks for the info. For us simple-minded folks, can you explain why the EPA can void the HD warranty on 2017 M8 models if we upgrade the CAM to after market instead of using the recommended SE CAM upgrades? I have a Stage 1 M8 Road Glide Special and would consider Stage 2 but when I went from Stage 1 to Stage 2 on my 2016 Road Glide Special the Torque and HP numbers did not move very much for the $ spent. I had V&H true duals and mufflers at the time. Thanks!
