Replacing stock 96 with SE 120R crate engine
Hello all,
After three years of saving and dreaming I have purchased a SE 120R crate engine to replace my stock 2007 Night Train (softail) 96 engine. My question for you all is has any one already replaced there 96 with the SE 120R and used a Zippers Thunder Max autotune ECM. I already run the Tmax ECM and love it. Zippers says it is compatiable with the SE 120R but i wanted to here from some one who is already running that config. Also will be using auto compression releases and a new digital Speedo / Tack.
Thanks for any advice!
speakerfritz
07-19-2011 09:54 PM
