Can you bolt the se 110 heads up to a 95 inch motor
Old 03-19-2014, 04:00 PM
misfitJason's Avatar
misfitJason
misfitJason is offline
Received 1,028 Likes on 651 Posts
Default Can you bolt the se 110 heads up to a 95 inch motor
OR is there machining required.
Old 03-20-2014, 02:51 PM
djl's Avatar
djl
djl is offline
Received 2,010 Likes on 1,489 Posts
The 110 heads will bolt on but the chambers are much larger and shaped for the matching pistons. Not a good road to head down; it's more complicated that just bolting them on.
Old 03-20-2014, 04:42 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
As djl stated putting 110 heads on a 95 is a really bad idea.
Old 03-21-2014, 09:20 PM
ranchodeluxe's Avatar
ranchodeluxe
ranchodeluxe is offline
You have 1/8 in difference in bore size. It will not work, but it is a great perf head for a four inch bore.
Old 03-22-2014, 05:49 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
If you brought it out to 98", with a custom piston, with the proper cam,
you MIGHT be able to use them at that point......maybe.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 03-22-2014, 06:42 AM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
we use a lot of 110 heads on builds,like scott said,98" maybe.they work good with minimal chamber machining on 107"`s & up (very nice 124" head)youde be better off getting your heads ported
Old 03-22-2014, 12:41 PM
Fairshake's Avatar
Fairshake
Fairshake is offline
Listen to the motor people who have given you great advice. Stay with your heads and have them worked on. You may choose a light clean up to the high dollar fixes. Later Fairshake
Big_O
Engine Mechanical Topics
45
01-21-2023 05:41 PM
128auto
06-22-2013 01:50 PM
hank-hill
EVO
10-26-2010 05:44 AM
harris48cars
06-05-2009 07:47 PM
purprotein
04-19-2009 05:24 PM
Quick Reply: Can you bolt the se 110 heads up to a 95 inch motor
