Cam upgrade stock engine
I've been talking to some people that say a cam upgrade will be the biggest bang for my buck in my stock 07 96" street Glide, even over a 103" big bore kit. True or False? What cams should I use? what else would I need in conjunction with the cam change? I've heard adjustable pushrods (which ones?) and new push rod tubes?
The short answer is YES....
BUT, it will not work properly unless you do it in conjunction with fuelling tweaks (ie a dyno tune) and preferabley a free flowing exhaust system.
Adjustable push rods are bloody handy if you do a lot of work in the cam area as you do not have to pull the rocker covers each time to remove the rods. They are also compulsory if you go to a high lift cam as using stock push rods on a high lift cam will result in the lifters not bleeding down enough - lots of noise will result.
Reuse the stock push rod tubes as they do not alter in length - just the push rods themselves.
with a andrews 57 better with more compression on a touring i av a 57 in a rk 98 ci set at 10 to 1 cp wfo larry headwork stage 1+ 26 is good choice for a 88 ci but for a 96 andrews 48 is better for just a cam swap u can use stock push rod but u need to remove gas tank and rocker if u choose adjustable less work u can use smith brothers push rod u dont av to change pr tubes with sm depend of the milleage i change lifter when i put a new cam when ur in the cam area change inner and outer bearing used torrington bearing and a tuner or dyno tune and feel like a new bike its the best bang for a buck if u go 103 to av good result u av to change cam anyway and head gasket maybe port job lollll always a question of what s ur target and whats ur budget
The Andrews 48H is a very good cam for your bike. I like adjustable push rods, but you can stay with stock if you like. I use S/E tapered adjustables. They come with shorter push rod tubes to make adjustment easier. S&S and others make 'quickee' adj. push rods with covers to match. Smith Brothers/Fuel Moto are good adjustables, but not 'quickee' style so a bit more fiddly to install.
Change the inner cam bearings to full compliment Koyo (formerly Torrington) and if the lifters have more than 20,000 mi. change them too. Gaterman or S&S would be my choice.
Yes a good cam and tuner is probably the best bang for the buck. I would do the pipes and A/C too for best possible results.
I have never run any of the Kury cams but when considering a set for a build I did some investigating and came to the conclusion that Kury cams respond to head work suited for the Kury cam profile which is atypical. If you want to run Kury cams, selecting a head porter that has ported heads and produced good results with those cams is cricital. Bob Wright used to be the go to porter for Kury cams and I think Dewey's Head Porting (Don Dorfman) has worked with Kury cams before as well.
