Stage 3 Big Bore 103" kit for my 96" TwinCam FatBoy 2011
Old 04-08-2014, 04:44 PM
bobbyfatboyg's Avatar
bobbyfatboyg
bobbyfatboyg is offline
Default Stage 3 Big Bore 103" kit for my 96" TwinCam FatBoy 2011
Ordered the kit and hi-flow oil pump and cam bracket, etc. Very curious how your experience has been jumping from 96" to 103" and the 259E cam on a FatBoy used mostly in the 2k to 4k rpm range, solo rider. I'm about 275lbs. as dressed in boots, jacket, helmet.
Anything special to tell them on the ScreaminEagle RaceTuner re-flash? Do you think needs a Dyno run or the re-flash for Stage 3 from HD Tuner o.k.?
Thanks
Old 04-08-2014, 05:19 PM
wurk_truk's Avatar
wurk_truk
wurk_truk is offline
It will need tuned by a professional, which is NOT your dealer. All of the HD flashes have to be EPA compliant anymore. So, with that kit and cams, there will be no EPA tune available for you.
How far are you from Pocono, PA HD? AT Pocono HD is one of the best tuners around, JD.
Old 04-08-2014, 06:28 PM
bobbyfatboyg
I could make it down there. How is Danbury CT H-D reputation for Dyno?
So, how much more power would I get from a Dyno tune on a 103 kit than from the EPA compliant HD download? I've done ALOT of readingon dyno tuning, but thought I'd get pretty close with the SE Race Tuner, esp. as already own it fro. Stage 1 install and V&H pipes. Thanks.
Old 04-08-2014, 08:50 PM
kyle8095's Avatar
kyle8095
kyle8095 is offline
I just finished up my 08 fat Bob I just installed the 103 stage 2 with the 255 cams I just got to do a little riding this past weekend and I love the torque output now 6th gear hill climbs now not constantly downshifting I did flat top cast pistons Se clutch spring new lifters Se tapered pushrods did a valve job Se inner cam bearings an a super tuner I'm recommending getting it tuned after break in mine has no intake or exhaust leaks but decel pops bad talked to my parts guy and he recommends a full Dyno tune after 500 miles
Old 04-09-2014, 08:10 AM
bobbyfatboyg
Thanks. I was thinking same way.... let my HD dealwr w no Dyno install it, break it in, then Dyno at good shop. Piwer sounds awesome. Doea it sound lumpier?
Old 04-09-2014, 09:26 AM
0ldhippie's Avatar
0ldhippie
0ldhippie is offline
Since ya all ready ordered the stuff I guess you'll find out. SE cams and heads are not high on my list of good stuff. A proper tune will help, a lot! Good luck!
Old 04-14-2014, 11:42 AM
bobbyfatboyg
Stage 3 kit I ordered is same as Stage 2, except a 259-E cam, as I understand. Also doing the high-flow oil pump and cam support billet bracket and some miscall. upgrades like hydraulic tensioner. Keeping this bike till 100k miles, I hope. And then my son till 200k, I hope. And then his.... ..... :-)
Ride safe. Thanks for comments.
bulldog182
Engine Mechanical Topics
19
04-23-2016 03:52 PM
14Electra-glide
03-16-2015 08:53 AM
neverhme
12-11-2010 07:43 AM
DHart
08-28-2010 01:04 PM
CruzinLow
04-20-2010 08:11 AM
Quick Reply: Stage 3 Big Bore 103" kit for my 96" TwinCam FatBoy 2011
