Twin Cam 88 engine miss between 1/8 - 1/4 throttle
Ok...been scratching my head for quite some time now on this and seem to have baffled my mechanic. Here's my issue. I have a 2001 Heritage Softail TC88 with Mikuni 42 carb, K&N 3910 air cleaner, and V&H Big Shot Long exhaust that misses/stutters between 1/8 and 1/4 throttle. It accelerates fine, but when trying to maintain speed, say 25 mph in 2nd gear, 35 mph in 3rd gear, or 45 mph in 4th gear, it misses to the point where I can feel the bike jerking and can hear the thumping in the exhaust. Here are the specifics on the Mikuni: Pilot Jet = 25, Needle Jet - 97, Main Jet = 160, Accelerator Pump needle = 50. I have tried a 20 Pilot Jet and same issue occurs. What's even more perplexing is I get the same issue with the original CV carb. I've troubleshot the fuel system i.e., vacuum petcock, changed fuel filter, checked tank vent, main fuel line...all good. Checked for intake leaks (WD-40 spray around intake manifold)...no leaks. I changed spark plug wires, swapped ignition module with a known good one, checked battery connections...still have same problem. Mechanic thought exhaust valve on front head was sticking...pulled both heads (just to be sure) and had them checked out/new seals installed...reinstalled and encountered the same problem. Not sure if this is an electrical, fuel, or mechanical problem, but any insight would be greatly appreciated.
That is a lean condition, yes.
Move the pilot up to a 27.5 and see what the response is.
I will say that most Mic's run ok with a 25.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
