evo top end noise when warmed up
Old 05-04-2014, 08:26 AM
dale8287's Avatar
dale8287
dale8287 is offline
2nd Gear
So to start list what's been done
This is a 1986 evo 1340
Heads where ported and polished
Valve job
New valves
New springs
Put new pistons
10:1
New andrews ev27 cam and bearing
Andrews adjustable pushrods
S&s lifters
Oil is 40/45 psi when cold at idle
The around 30 psi when hot at idle
It runs great with no problems other then top end chatter noise when warm can not figure it out I pulled the heads and brought them back to the shop that did them he went through them pulled them apart and found nothing, Checked rocker box s to see if new springs maybe hitting
Nothing, valves and pistons have plenty of clearance
My question is if the valve springs he used are to heavy would it cause the valves to slap shut? or could the springs make the noise themselves like the inner spring was contacting the outer? the noise is coming from the top of the head
It's definitely not a lifter problem or pushrod adjustment been thru that a 100 times and replaced both figuring something was bad but not the case
Any ideas or suggestions please
Thanks
Old 05-05-2014, 01:03 PM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
What lifters(?)and what are the pushrods adjusted to?
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 05-08-2014, 09:08 AM
dale8287's Avatar
dale8287
dale8287 is offline
2nd Gear
There S&S Hydraulic lifters
The pushrods are at 3 full turns (18 flats)
Old 05-08-2014, 09:31 AM
Hillsidecycle.com
Sponsor
We set those 32 tpi S&S pushrods to .140-150" lifter load here.
That 27 does have a pretty aggresive ramp.
Scott
Old 05-08-2014, 10:48 AM
dale8287's Avatar
dale8287
dale8287 is offline
2nd Gear
Should I try re adjusting them again
I've adjusted them a couple times now but the noise in the top end will not go a way
They've been adjusted from 2, 2 1/2 now 3 turns and the noise has never changed
Old 05-13-2014, 08:20 PM
Hillsidecycle.com
Sponsor
What oil, Dale?
Scott
Old 05-15-2014, 08:30 PM
dale8287's Avatar
dale8287
dale8287 is offline
2nd Gear
amsoil
Old 05-15-2014, 08:41 PM
Hillsidecycle.com
Sponsor
Next oil change try some 50W Spectro, or Torco.
Scott
Old 05-17-2014, 04:12 PM
Ripcurl's Avatar
Ripcurl
Ripcurl is offline
Stage IV
I've heard that it's not a good idea to run amsoil in the older evos. I'm an amsoil guy in everything else but I was told that the evos actually need some decent viscosity and that amsoil is too smooth. Please let me now if you you've heard different.
Old 05-18-2014, 08:54 AM
kink04fxd's Avatar
kink04fxd
kink04fxd is offline
[QUOTE=Ripcurl;12737965]I've heard that it's not a good idea to run amsoil in the older evos. I'm an amsoil guy in everything else but I was told that the evos actually need some decent viscosity and that amsoil is too smooth. Please let me now if you you've heard different.]
Here we go..........
Quick Reply: evo top end noise when warmed up
