1995 Dyna FXDS rear cyl smoke at idle consuming oil
Need advice, 1995 FXDS Dyna Convertible 80" with 29,000 original miles Evo all stock except for screamin eagle can and ignition, k&n air filter and SE short shot pipes. Bike had been sitting for around two months due to a baby on the way, installed new battery and fired her up first warm day of spring. Notices small amount of whitish smoke from rear cylinder exhaust only. Cant tell if its blueish or not but it's not black. Warmed her up for 30 minutes still same amount of smoke. Tried revving and slamming throttle shut, no difference. Seems to idle Finland rev fine no miss no slag. I did replace the rocker box gaskets (everything from box up) as one leaked slightly several hundred miles ago, long before i noticed the smoke. Where do i start? Please help i want to do the work myself i have a service manual but want to invest the $ in the tools rather than pay the dealer.
Last edited by mojojones1; 05-08-2014 at 07:09 PM. Reason: Forgot to mention 29,000 original miles
