Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Anybody know an easy way for the MM throttle body to fit a Ultima 113" engine? Wanting to swap out my evo for the 113", but have magneti marelli FI. Any help would be great.
I threw my M M Fi in the garbage and ran the super g carb easy swap but you qill need nose cone ignition kit with coil. You will also loose cruise controll
Have you asked Ultima? You can't be the first customer to do that!
ill bet you he would be,**** can the MM EFI & put a carb on it.ultima motors have no places for any sensors for EFI (unless somethings changed since ive sold one)plus a MM t. body is barley good enough for a mild 80" motor,let alone a 113"
I have spoke with them and was informed that it will work except for the throttle body would need to be modified to fit. Any idea what sensors are connected to the engine?
