Carbon Build-up...Prevention
Combustion chamber cleaning: GM Top Engine Cleaner does a hell of a job of this. When I was a Benz mechanic, we used this stuff regularly on cars that got driven... what, softly? Lightly? And ended up with carboned/coked up combustion chambers and valves. It is (or at least was) available in an aerosol can which works well on bike carbs/throttle bodies. Follow the directions on the can closely. And make sure to point the exhausr AWAY from your garage and house. The stuff REALLY stinks when the motor gets going and blows it and all the carbon, etc, out the exhaust.
If I can figure out how to post pics via my phone on here I'll post up my venting setup. It's not all that visible byt what can be seen of it looks at least tolerable. Actually pretty good.
Here is one way to skin the cat. Could be plumbed higher if one wanted to hide as much of it as possible behind the air filter. Most is out of sight when the filter cover is in place.
EDIT: Forgot to mention that KrankVents are attached at the head breather outlets; can't see for the filter.
Duralt is another good fuel conditioner; used to be available at H-D dealerships and touted by the MoCo as their recommended fuel treatment.
http://www.fueladditivestore.com/duralt.html
Back when EFI hit the market in the automotive industry and coolant temps went regularly to 210 degrees F, coupled with EGR valves, the carbon build up in the small 4 cylinder engines was unreal, to the point were exhaust vales would hold a large mushroom size piece of carbon buildup that would totally block the exhaust port creating a major skip in the engine (no air out, makes no air in, makes no power) we actually were able to clean all that with MMO. To date I still use in all my cars and my Harley. Crankcase and Fuel tank. love it, swear by it....Over 30 years......
Here are a few pix of my vent setup. I still have to devise a catch can. I'm trying to dream up an aluminum can with a vent filter and drain plug, possibly with a couple of baffles to provide a "torturous path". We'll see how that turns out. Maybe attach to the back of the transmission pan or something. It's made with 4AN PTFE (Teflon) braided stainless from each breather attachment at the air cleaner (the passages into the intake are welded shut); the union under the air filter is a Tee that is 4AN on the ends, 6AN in the middle; there's a KrankVent under the motor, between the motor and trans pan; the line then runs along the trans pan on the exhaust side and you can see where it ends (with no fitting or anything right now) at the back of the frame by the side cover. This is where I am going to try to put a catch can of some sort, like I said, maybe attach to the back of the trans pan or something.
I have vented mine similar to yours but without all the AN fittings, just plastic tees and nineties and black hose. The current catch can is fabricated from a small piece of capped PVC stuffed with the mesh that you find in the OEM head breathers. Route of the out hose is between the cylinders, low in the V down as yours is routed to a small inline lawnmower fuel filter. After a hard 300 mile ride, there might be a drop that drips out of the small filter but nothing of any consequence.
I am also working on an aluminum catch can of some sort but haven't figured it out yet; need a really small filter. Not so worried about a drain plug; not that much blow buy.
I have vented mine similar to yours but without all the AN fittings, just plastic tees and nineties and black hose. The current catch can is fabricated from a small piece of capped PVC stuffed with the mesh that you find in the OEM head breathers. Route of the out hose is between the cylinders, low in the V down as yours is routed to a small inline lawnmower fuel filter. After a hard 300 mile ride, there might be a drop that drips out of the small filter but nothing of any consequence.[/QUOTE]
I saw a pretty good catch can in a speed shop in Vegas (which is where I was when I built this motor initially); it was maybe an inch and a quarter in diameter, had a K&N type breather/filter on one end and pipe thread on the opposite end; I almost bought it, but it was $50 and had no guts, was just empty. I figured I could machine something nicer or as nice for a lot less, plus it was a little long (6" or so) and would need some welding on for brackets, etc plus baffles inside. Couldn't see paying $50 and doing all that to it. Maybe a PVC catch can is in order until I get something like that figured out. I have a few spare head breather "sponges"; I was thinking Scotch Brite, but I bet those head breather sponges would fit right inside a standard size pipe.
