10.5 vs 11.0
Old 08-29-2014, 12:06 PM
instag8tr's Avatar
instag8tr
instag8tr is offline
Default 10.5 vs 11.0
I am putting together a 103" and I am looking for any info on gains or losses between 10.5 vs 11.0 pistons. I will be using MVA heads.
Old 08-29-2014, 05:06 PM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
what cams? match the compression to what the cams call for.if your using cams that like 11.0-1 and you run 10.5-1 it`ll be soft,if you try to squeeze a cam set that's likes 10.5-1 and you set yhen at 11.0-1,detination & heat probs will occur
bedelman10
Touring Parts
10-30-2017 11:55 AM
bedelman10
Softail Parts
04-18-2017 04:15 AM
bedelman10
02-03-2017 05:45 PM
bedelman10
Dyna Parts
02-03-2017 04:40 PM
Ganno57
02-24-2006 02:10 AM
Quick Reply: 10.5 vs 11.0
