Big bore
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
So what does one do to get higher numbers with the parts I have?
I can think of three or four small changes but all are expensive relative to the gains now that the build is complete. Different cams, head work, thinner head gasket and a different baffle in the pipe.
I believe anything anyone suggests can help the OP and others who read this when they plan this work.
If you are happy with the way the bike runs, ride it and pretend you never saw the dyno sheet. If you are not happy, get your wallet out because none of the changes you listed above, done individually, will produce significantly better numbers. That would require some combination of the changes you mentioned, like head work and a cam change.
rollnthunder
Engine Mechanical Topics
11-18-2014 06:56 AM
nightrider05
Exhaust System Topics
01-10-2013 09:00 AM
