88 Softail with Rivera Heads
Old 09-15-2014, 06:10 PM
lugnut262's Avatar
lugnut262
lugnut262 is offline
Default 88 Softail with Rivera Heads
I recently bought a 88 Softail it has S&S jugs and Rivera 4 valves heads. I had it started once for about 20 sec. then died. The problem I have is it don't want to turn over. For what I know so far is that it just might be to much compression. It want to turn over real slow to where it don't turn at all with the starter wires smoking. The cable are the real good one. Battery is new. and so is the starter Solenoid. The starter look like it was change not to sure. And tip what I can do? I hate to go buy a new starter but I just might have to.
Old 09-17-2014, 04:13 PM
prodrag1320's Avatar
prodrag1320
prodrag1320 is offline
how dose it crank with the plugs out?
Old 09-19-2014, 11:55 PM
lugnut262's Avatar
lugnut262
It seem to turn over ok have it running for about 20 Sec.
Old 09-20-2014, 07:55 AM
prodrag1320
what cam?
Old 09-29-2014, 08:46 PM
lugnut262's Avatar
lugnut262
I don't know what cam is in there. I should pull that apart and check it out.
Old 09-30-2014, 06:40 AM
prodrag1320
use a longer duration cam
grieker
10-13-2014 08:03 PM
LDB187
03-04-2014 10:21 AM
LDB187
03-03-2014 08:50 PM
allenodell
Engine Mechanical Topics
03-20-2012 04:00 PM
Blown 331
EVO
20
01-08-2008 04:08 PM
Quick Reply: 88 Softail with Rivera Heads
