Generic Dyno Jet Kit
I took it back apart this morning, the clip was in the third groove from the end with three washers under it...
I have never tuned a CV carb so this is new territory for me (maybe I should have started a new thread). I put it back together with no spacers and the e-clip n the 4th grove. Right now it is backfiring through the carb at about 1500 rpm... Baby it past there and it will accelerate fine. Almost seems like the slide is opening early??
As far as I know the only engine mods are air filter and exhaust.
There shouldn't be any washers under the clip and there should be a spacer on top of the clip.
To check that you need to hold the white plastic piece upside down and put the needle into it, if the circlip slides into the hole or if it doesn't sit nicely against the outside of the hole then you need a spacer in there (usually comes with the kit but the kits vary).
Take the spacers out and move the clip down by 2 grooves and try again.
I had a choice of needle and my Indy said to use the fattest one. If you should have the spacer above the clip and its missing then the needle will oscillate as the slide opens and closes and this makes them run bad.
I had no spacer available so I made one out of JB weld.
Well I worked on it more today with the result being that it is back on the bench, taken apart.
I moved the washers to the top, not much better, off idle backfire through the carb. Started looking a little harder, turned the idle air mixture screw all the way in and the bike did not stall, ran a little rougher, but I am thinking I should be able to starve the engine doing this (at least on other engines I have worked on... usually I turn the idle air mix screw in until the idle changes and back it back out a little) ?
I did the propane test to make sure I had no leaks and I could not detect a change in how the engine was running.
So I took the carb off and back apart to check the float level, check for proper assembly ect... - float level checked out at ~ 0.419" @ 17º tilt. I didnt see anything glaring that was wrong. Then I started thinking that possibly the enrichener valve is not sealing properly?? Maybe the 48 idle jet is just too big?
So far I am thinking that my next steps are to get a 45 idle jet and a new enrichener valve.
You guys have any ideas?
edit: this does have the dynojet emulsion tube with two holes in it.
I had this jet kit, still do on the bench, I lowered the clip one more slot from where you have it which raised the needle. Ran a 45 pilot and it seemed better. I've since gone and changed to a whole CV Performance carb jet kit and a brand new vacuum slide and I can't get rid of the off idle cough same as you're getting now. Try the needle up higher with the clip lower see what you get. Others may offer better advice just sharing what worked for me before I spent $50 and made no progress. Also, I changed the intake seals too. No difference. Before the season ended I moved to a 46 pilot but never got a chance to test it.
If you pulled the emulsion tube, did the needle jet come out? If so it may have been put in backwards which will make it run lousy. The squared end butts up to the emulsion tube as shown here:
http://www.cv-performance.com/harley...tuning-issues/
Might also try the CVP Velocity Needle
http://www.cv-performance.com/cvp-velocity-needle/
The part that really confused me was that when I turned the needle all the way in I could not change the idle much.
That's because you're running a 48 pilot. If you downsize that the idle mixture screw will change
