HOT Wires Coming From Stator??
Hello, just put a new battery in a 97 Heritage Soft tail today. I check the voltage and all the number were in spec but when I felt the wires coming from the stator going to the voltage reg they were very HOT. What could be causing this I am stumped?
Bike has a Compu fire stator, rotor and voltage reg.
Thanks very much !
Thanks very much !
Received 4,317 Likes
Go to the sticky posted by Dr. Hess and check your system according to those instructions. Pull the stator plug, check for shorts, continuity and AC output. If you have a problem.....this inspection/evaluation will find it. There are some errors in the instructions posted in the General Mechanical Section....use the one posted by Dr. Hess in the EVO section.
