Exhaust/Cam options on built 80" Evo
Old 10-06-2014, 06:23 AM
98flhrci's Avatar
98flhrci
98flhrci is offline
6th Gear
Default Exhaust/Cam options on built 80" Evo
Hey everybody,
I'm rebuilding my 98 RKC over the winter and am looking for some input on a good 2-1 system. The engine will be running the 89" stroker kit from S&S along with .030 pistons.
I have been looking into a Supertrapp supermeg system because of the ability to tune it however you like. I would like something that's going to optimize my total hp/tq output, not something that is the loudest.
I was also told my S&S that a 561 cam and 580 lift valve spring kit would be coming with my flywheel, but later told that it wouldn't. So now I'm wondering if I should go with that set-up, or do something completely different. I'm not sure what the stock Evo heads are set up to handle in terms of lift, and I'm currently not doing any head work other than basic maintenance.
Any input or help would be awesome. Thanks.
-Ben
Old 10-06-2014, 08:57 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,803 Likes on 3,311 Posts
580 is a lot for stock heads n springs, depending on the compression either a w-6 that works very well at 10:1 or a w-8 that works real well for 10.8:1 but you will have to go to better springs and porting for the w-8. The w-6 Will work with stock heads but bigger valves and compression are the key to making it all work.
Old 10-06-2014, 08:58 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,852 Likes on 2,419 Posts
I have a Supermegs on my Evo, admittedly with an S&S 107" engine. The engine runs remarkably smooth since installing that exhaust and it is just great. I can recommend it. Not being American I don't like loud exhausts and mine is fine.
Old 10-06-2014, 10:22 AM
98flhrci's Avatar
98flhrci
98flhrci is offline
6th Gear
S&S claims with the 89 inch kit that compression will be at 9.25:1 with stock heads. The valve springs are getting changed out too, I should have mentioned that. Do you think 580 lift springs / 561 cam would be too much with the stock heads?
Old 10-06-2014, 10:25 AM
98flhrci's Avatar
98flhrci
98flhrci is offline
6th Gear
Not being loud is perfectly fine with me. Did you have a hard time tuning it in with the disks?
Old 10-06-2014, 10:41 AM
98hotrodfatboy
You will probably have to go beehives or similar with a rating of .600 I really don't think stock will cut it.. and yes you can get better performance but to optimize the cam a head job would be most beneficial not to mention the byproduct of more compression included in the head work.
Old 10-06-2014, 11:59 AM
SeaZund's Avatar
SeaZund
SeaZund is offline
D&D FatCat
Old 10-06-2014, 01:38 PM
WP50's Avatar
WP50
WP50 is offline
Received 1,698 Likes on 1,153 Posts
As to the cam , many here know much more than me.
The exhaust D&D fatcats are hard to beat.
WP
Old 10-06-2014, 02:02 PM
98flhrci's Avatar
98flhrci
98flhrci is offline
6th Gear
WP
Anybody have dyno sheets of before and after? I'm going for max output with this build, not necessarily the loudest or best looking.
Old 10-06-2014, 02:33 PM
D_gyver's Avatar
D_gyver
D_gyver is offline
if you want max output your going to need head work done. valves springs and at the very minimum a good street port job. and with any large cam you need compression
rule of thumb is 9.6:1 and that's corrected compression ratio. a stock 80" with a W-6 cam needs 10.43:1 static compression and a W-9 needs 10.99:1 to achieve the golden number of 9.6:1 CCR and that's as high as you want to go on pump gas.
Quick Reply: Exhaust/Cam options on built 80" Evo
