gas tank ??
In my case, I had about 1/8 of rusty sludge in the bottom of each tank from sediment in the fuel settling out. It was clogging the fuel strainer and accumulating in the carb. Cleaning it out by the method I described did no harm.
I would have used acid if I were trying to remove rust. In my case I was trying to remove sediment build up from 100,000 miles worth of gasoline, without removing the chromate lining from the inside of the tank (back in the '90's, H-D actually painted the INSIDE of the gas tanks, not sure if they still do).
I took off going to a swap meet in Ft Worth on Sunday. I did not make it far - started spitting and sputtering. When I stopped to try and understand what was going on - I noticed the carb was overflowing. I nursed it home and pulled the carb and sure as *****, it was full of rust and stuff. The petcock screen was old, dead, and had failed, allowing all that crap to go into the carb.
The tanks have been pulled and are now in the process being treated with Metal Rescue. I am using this as an excuse to put on a new petcock and filter (belt & suspenders). This is obviously a drag but what do you expect when you buy something that sat neglected in someone's garage for 17 years?
Received 14,169 Likes
