Interesting problem
#73
#74
Received 4,317 Likes
I just hope the guy that said he could get it out knows what he is doing.
I'm going to guess he does because he works as a welder at a muffler shop for a living.
I've never welded a damn thing in my life.
#75
#76
Is that bolt #3 that goes into bracket #32?
How much is a new bracket??
Drill out the through bushing and bolt #3 at the same time from the back side.
UPDATE
My Bad, I see that on your bike the upper bracket is bolted to the frame, in my parts manual it is welded to the frame.
It became apparent when the manual called for two #3 bolts but my picture only shows one. ( The lower)
UPDATE
#77
UPDATE
UPDATE
#78
Get the smallest "nail set" you can find. (They make them to set different size finishing nails) Get a really good one.
Place on drill bit and using a single stroke of the hammer hit the set like you are setting a nail, this should shatter the bit. The difference between a "set" and a "punch" is the set has a machined ring on the end. This drives into the top of the nail and keeps it centered while the hammer applies the force. If you look at a nail after it is "set" you will notice the indenture in the nail, this is where the stress will come from to shatter the bit.
A "punch" OTOH is just pointed and does not set up the stress force, just makes a dimple in what ever you are driving, sometimes they are blunt and just applies a force to push through without applying and kind of stress force to the object.
2) If you can get to a couple of inside threads in the bracket, get a "Bottom Tap" of the correct pitch and diameter. This is a tap that isn't pointed on the advancing end but flat and is designed to cut threads to the bottom of the hole you are tapping. When asking for one of these if that person looks at you like your are standing there with your dick out there is an alternative. Take a regular tap of correct size and cut the end off. The tap is really hard and brittle also, now shape or make sure the bottom is "flat" and full diameter, start the tap in the hole. Make small headway and back out and vacuum or blow out any loose material. Do this until it bottoms out, no oil, work slooooooowly.
As the tap advances it will crush the drill bit and remove the old bolt. This is risky if you can only start with a couple of threads, three is recommended. On the plus side you may not save the original diameter of the hole but all you will need to do is drill out the bracket to the next size bolt and re-tap the hole.
That casting is made with enough meat to allow for this, as long as the bushing side is 1/3 of the diameter of the hole you will be OK as far as strength of the fitting goes. And it may not be that size now, which means that there is enough meat to accomplish the task and the strength of the fitting lies else where and not through this bolt hole.
#79
I like the idea of the nail set but I'm not so sure of using a tap to crush the drill bit.
Have you personally done it?
#80
Ride Safe,
Harold
